Drivability issues
Old Jul 6, 2008 | 11:39 PM
Terrokee's Avatar
Terrokee
Default Drivability issues
I have a 89 5.0 and just got through rebuilding the engine. Its machined .030 over and I added a few upgrades in the process. I have some Ford Motorsport aluminum heads equivalent to GT40 heads. Changed to a Cobra intake, put a E303 cam in it. When I start it it runs but It runs rough and the timing is all over the place and even when I adjust it witha timing light It wont run on the 12 degrees I try to set it at. I do have the spout connector off when I adjust it. The vacuum is low at 5-8 inches at idle. It sometime will stall too. I try driving it and It is lacking in power and will stall when I come to a stop. I put it on a gas anylizer machine and it is running no CO at all. I called a Ford Motorsport engineer and he said I need Ford motorsport intake gaskets instead of the Felpro I was using and the Roller rockers instead of the stock ones. I have changed those out and still runs the same. I checked fuel pressure And its 42psi in spec. I have checked TDC with a piston stop to make sure the timing marks are correct and it checks good. I ran out of ideas any one have more for me to check? Thanks Terry
Old Jul 7, 2008 | 07:47 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Drivability issues
well as for needing the fms gaskets...that's horse shiz!! fel pro lower will work fine and equivilant to a cobra or gt-40 with the round holes will work fine as long as it all lines up...first thing I'd do is run a koer test and look for codes..if none exist second thing I'd do with low vaccumis look for a vaccum leak.....if you have access to a smoke machine.. that'd make life simple
Old Jul 7, 2008 | 07:35 PM
Terrokee's Avatar
Terrokee
Thanks for the reply I figured he was trying to sell me his product. I did a KOER with a NGS and found no codes. I will grab the smoke machine from work and try that. I did find a article on another forum about intake manifolds particular to the GT40 and Cobra intakes. The one that say Made in China are bad. I looked under mine and it does say that. I bought it through Summit. I looked at a stock Cobra manifold today and compared to mine the mounting flange size is much smaller on mine. That may be the problem. I hope the smoke machine will verify this. Thanks Terry
Old Jul 7, 2008 | 07:38 PM
mjr46's Avatar
mjr46
GOOD!!!!!! YOU HAVE ACCESS to a smoke machine and the NGS WOW i'M IMPRESSED.......most don't thumbs up to you which will make diagnosis hopefully quicker
Old Jul 8, 2008 | 06:43 PM
Terrokee's Avatar
Terrokee
It Helps when you work at a garage with mostly fords in it. Ford police cars that is. I will let you know what I find.
Old Jul 8, 2008 | 08:05 PM
mjr46's Avatar
mjr46
cool!! good luck!!
Old Jul 8, 2008 | 08:20 PM
aode08's Avatar
aode08
just had this issue,
your prob 180 * off, it will run (almost normal) but no power.
setting it to 12, with the light connected to the passenger side cylinder, the very first one up front.
Old Jul 9, 2008 | 07:30 PM
Terrokee's Avatar
Terrokee
I thought it was that at first so for kicks I turned it 180 and it was worse. I fugured out that the intake is not sealing to the heads. I have tried several name brand intake gaskets and it wont seal. I found some redesigned Felpro gaskets today and will give those a try for the 3rd time. I have read on another mustang forum that the Cobra intake I have is a off brand of the real cobra intake and they are junk. I may be finding another intake.
Old Jul 9, 2008 | 08:44 PM
mjr46's Avatar
mjr46
what is your ..whole build so we can possible reccommend an intake.....so the smoke test worked??
Old Jul 9, 2008 | 10:57 PM
cheetha94607's Avatar
cheetha94607
try taking your distributor one gear off and see how it run. dont ask why but for some stangs it would make that much of a differance.
