Jack question
Old May 5, 2005 | 06:04 PM
Dearborn5.0's Avatar
Dearborn5.0
Default Jack question
What type of floor jack do you use?
From the bottom of the V bracing bolts (under front subframe) to ground: about 4"
Craftsman offers:
2 ton Aluminum racing jack: min height 3.5"
Pro: Will fit under car
Con: only 2tons
All other jacks (3, 4 tons) min height is 5"/5.75"
Pro: safer with more tons
Con: Wont fit under car
What should I do?
Old May 5, 2005 | 06:07 PM
95_302_StangMan's Avatar
95_302_StangMan
Default RE: Jack question
i use the one that came with or if that is gone then just use the small one at first then use the big one
Old May 5, 2005 | 06:10 PM
stanglx2002's Avatar
stanglx2002
i just use a small on and jack up one side at a time then put jack stands under it. you never put a full 2 tons of weight jacking up are cars
Old May 5, 2005 | 06:23 PM
92hatchLX's Avatar
92hatchLX
We use a 2 ton jack, that will jack up 4,000 pounds. Now unless you plan on adding weight to you're stang go ahead and get one, they are very versatile and WAY lighter than the larger jacks. Just remeber to use jack stands when ever you jack something up.
Old May 5, 2005 | 07:42 PM
fordguy17's Avatar
fordguy17
also use wheel chocks and pull your e-brake.
Old May 5, 2005 | 07:47 PM
Pure5.0's Avatar
Pure5.0
If you balanced your entire car on a stick and placed that stick on a jack and tried to jack it up....then a 2 ton jack will be close to its limit....but still work.
You would have no use for a 3-4 ton jack unless you were jacking construction equipment or semi trucks.
A 2 ton jack will do more than you ever will need for your stang.
Old May 5, 2005 | 08:15 PM
Magiarn71's Avatar
Magiarn71
I have 2 Craftsman 3 ton jacks that came with stands, but usually use 6 ton stands because they're taller. Sometimes the jack is a little taller than air dams and things, so I lift on the car a little by hand and shove it under. Ive actually had something off the ground with a jack on each end, but I wouldnt recommend it....
Old May 5, 2005 | 08:58 PM
86HOGT's Avatar
86HOGT
I use a two post lift .
Old May 5, 2005 | 09:11 PM
doobs's Avatar
doobs
we have a lift...install it in your house and get an extra garage spot!
Old May 5, 2005 | 10:27 PM
Pure5.0's Avatar
Pure5.0
ORIGINAL: doobs
Alright we don't need any bragging in here. All of us would die to have a personal lift at home. I know I sure would
