drag radial tire pressure
so im goin to the track and gotta set of nittos for 50 bucks the other day :D... its a 94 with 290 wheel and 373's. the nittos are 245 50 16 and im wondering what tire pressure i should run? also i know i should prolly just play around, but anyone have any advise on where i should launch at?
any help would be greatly appreciated!!! thanks |
RE: drag radial tire pressure
o and let me know if you want more detailed info
wat kind of nittos u runnin tha 555 r's or tha 450s!
n i launch mine car at 5 grand but i hav mickeys et streets n u cant jus pop tha cluth either u gotta eaz it out but still fast takes practice n bein that u hav such a small tire width i would try it from idle first jus 2 see wat it does |
If they are the drag radial nittos i would start at 15 and go from there. If not the drag radials go with 21 ish
ohh n i would set tha tire pressure between 12 n 15
thanks for the help buddy, they are555 r's... they hook pretty well on the street from 1500 slippin the clutch...def still have a lot to learn to launch this car but im sure it jus takes some practice and some playin around alil bit
start at 15-19 psi and adjust if necessary.....[8D]
yeah i like 18-ish on my mickey radials
heat them up really good and try launching at 3000-3500 , if you spin real bad either drop pressure or heat them up more. don't be satisfied til you get 60 foots of 1.8 or better |
