what pushrods to use?
Old Jul 13, 2008 | 07:19 PM
five0fm's Avatar
five0fm
Default what pushrods to use?
i need pushrods for a solid roller with Seat Pressure: 249#Open Pressure: 605# @ 1.203" or .647" lift and Spring Rate: 550 lb/inch. it wont be spun any higher then about 6100 rpms. what pushrods do you recommend.[/align]
Old Jul 13, 2008 | 08:16 PM
1991LX5.0's Avatar
1991LX5.0
Default RE: what pushrods to use?
are you asking about length or steel vs. chromemoly? For length you need to get an adjustable pushrod and measure because every set up will be a little different and you NEED chromemoly of you are running guide plates which judging by the cam specs im guessing you are
Old Jul 13, 2008 | 08:34 PM
five0fm's Avatar
five0fm
i have the lenght. im just debating on what kind of pushrod. i mean i see the same things for 86-155 bucks and idk what to pick. they all say the same thing. heat treated chromemoly same wall thinkness and everythng
Old Jul 13, 2008 | 08:38 PM
primetime5.0's Avatar
primetime5.0
im using TF pushrods in mine.. work well and were cheap
Old Jul 13, 2008 | 08:41 PM
five0fm's Avatar
five0fm
primetime whats your set up like and what kind of spring pressures do you have?
Old Jul 13, 2008 | 08:49 PM
1991LX5.0's Avatar
1991LX5.0
im using trick flow as well, just make sure they are 5/16, ball end, and oiling
Old Jul 13, 2008 | 08:50 PM
primetime5.0
to be honest with you I dont know what my spring pressures are, the cam is pretty small 555 intake, 565 exhaust.. pulls to 6k fairly easily
jtmustang's Avatar
jtmustang
^^^^yep yep same here trickflows , chromemoly 5/16 .....100 bucks....no problems other than my noisy crane rr's
Old Jul 13, 2008 | 08:56 PM
five0fm's Avatar
five0fm
any you guys are all using hydro rollers? i have a solid roller and i just dont want the rods to deflect or brake b.c of the strong spring pressures
Old Jul 13, 2008 | 09:00 PM
jtmustang's Avatar
jtmustang
talk to whoever u bought your cam from ... by the way which cam is it , or whos cam is it.....
