5 Lug Conversion Braketastrophy!
Old Jul 16, 2008 | 07:51 PM
86HOGT's Avatar
86HOGT
Default 5 Lug Conversion Braketastrophy!
Hey guys, it's been a while posting here...
I just got to take my 1986 GT out after completing the 5 lug conversion. I used SN95 rear parts and for the fronts used 2000 spindles and brakes. I used a master cylinder from parts_plus_more on eBay, i'm guessing it's a 1986 Town car, but his came with brake line and an adapter. Finally I used a Summit adjustable proportioning valve at the firewall on the passenger side firewall.
Anyway we just got the system bled yesturday including bench bleeding the master cylinder first on the car then bled the calipers starting rear right, rear left, front left and front right.
Took the car for it's maiden voyage and it couldn't stop to save its life! The old brakes were better! Ha!
The pedal is high and very stiff like there's no boost. But you could give it all you got and no braking power. The engine makes enough vacuum I'm sure even though it's built. even if it didn't have vacuum it should still stop better than this I think.
The only thing that comes to mind is maybe a pushrod adjustment? All four rotors did feel pretty hot after only going 5 blocks at 30mph. but after immediately jacking the car up the wheels spun freely.
Any suggestions, guys??
Old Jul 16, 2008 | 08:27 PM
ewgoetz's Avatar
ewgoetz
Default RE: 5 Lug Conversion Braketastrophy!
did you try adjusting the prop valve? Also did you stomp onthe brakes when you took it out? If you did stomp you may have glazed them. If you did than take off the pads and sand them lightly and hit the rotor with some sand paper or a biscuit with a light grit. I think the prop valve may need adjusting or you hooked it up backwards possibly....
Old Jul 16, 2008 | 08:36 PM
86HOGT's Avatar
86HOGT
I put the valve all the way in to allow full rear brake pressure but now that you ask if I put it in backwards, I never thought of that, that would be a rooky move.But they bled okay... I never could "slam" on the brakes. It wouldn't evenstop goodjust backing out the driveway. I knew right away something wasn't right. They never had a chance to get glazed. I can't check the valve tonight, but I'll let you know.
Old Jul 19, 2008 | 02:44 PM
black89gt's Avatar
black89gt
bump!i have the same problem!!
Old Jul 19, 2008 | 05:41 PM
absolutbspec's Avatar
absolutbspec
The brake petal being high and stiff is normal. When i did my conversion i called maximum motorsports to help me out and explain some things. The only way to fix that is to get a new brake booster which will set it somewhat back to normal but there is nothing wrong with the stock one unless you want the old feeling back.
The prop. valve doesnt stop break power to the front...i started at nothing to the back and still had better braking power stock. That wouldnt cause the issue your having.
The push rod adjustment is a good thought. My mechanic adjusted everything and the braking power did get better and it didnt feel like i was floating on ice anymore so i know how you felt with the maiden voyage. I was thinking ...oh crap i just screwed up my car....Never even used a bumpsteer kit and everything worked out great in the end.
Old Jul 19, 2008 | 11:49 PM
blwn93gt's Avatar
blwn93gt
from everything i have read, the stock booster is inadequate. you can upgrade to a 94 up booster. its larger in diameter and will give you more brake pressure. i hear they can be a little tricky to get in because of the size but its possible. i am going a different route. hydroboost from a 2001 mustang.
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
Oct 7, 2015 07:02 PM
DCole24
Sep 11, 2015 10:50 AM
