MGW Shifter
I bought the MGW shifter for my mustang about two months ago and when I installed it, it didn't feel like it needed breaking in like everyone says it needs for a while, it felt perfect... Well recently, it's been hard to get into any gear. When I am shifting regularly, it stops inbetween every gear. When I'm slamming through gears fast, it just kind of hesitates to go in but it is not as smooth as when I first got it. Is this normal? Does anyone else's MGW shifter catch inbetween gears? When I bought it, I just thought nobody EVER grinded a gear with it, but I have several times because of this hesitation...
sounds like more of a tranny problem, but adder said he had the same thing happen, i for one, havent, but i dunno, sounds like you should have broken it in
ive had mine for a similar length of time, and its fine
Sounds like you need to adjust the clutch, do you have an adjustable cable and a firewall adjustment piece as well. My car does the same thing when the clutch does not release in just the right spot.
junior04
Sep 28, 2015 10:53 AM
