trans. vibration at 80mph
Old Jul 23, 2008 | 10:10 AM
jagman454's Avatar
jagman454
Default trans. vibration at 80mph
Finished my AOD-T5 swap, everything runs good, but when I get up to 80mph I get a decent vibration and humming comming from my trans I can feel it threw the shifter also, I used a brandnew flywheel when I put the T5 in...... I can only think of the flywheel messing up, it never did this before in my auto....do i need to pull the flywheel?
Old Jul 23, 2008 | 10:59 AM
deadcarnahans's Avatar
deadcarnahans
Default RE: trans. vibration at 80mph
Wrong flywheel? Check the part # to make sure it's the right one. I would think it is the right one, otherwise it would vibrate at all speeds.
I'd look at the driveshaft. Remove it. then run the engine in gear up to speed and see what happens.
Old Jul 23, 2008 | 11:19 AM
jagman454's Avatar
jagman454
Good Idea...
Old Jul 23, 2008 | 12:49 PM
nseoi's Avatar
nseoi
U-Joints, check the driveshaft
Old Jul 23, 2008 | 12:55 PM
mustangsneverdie's Avatar
mustangsneverdie
check the trans mount to make sure its good and tight
Old Aug 1, 2008 | 07:49 PM
jagman454's Avatar
jagman454
removed the driveshaft, checked the trans mount (looked good), and when I ran it threw the gears I got the same symptoms just at a higher speed.
P.S. this is the first time I've installed a clutch, but the weird thing is I only get the vibration at high speeds not lower speeds....
Old Aug 2, 2008 | 08:36 PM
nyfreakinrican7's Avatar
nyfreakinrican7
Was the tranny used,new or rebuilt? I'm asking because I had a similar vibration with a used tranny I have and it was the tailshaft bushing that was worn out. It gives the driveshaft play where it enters the tranny.
Old Aug 3, 2008 | 09:42 PM
jagman454's Avatar
jagman454
I rebuilt it, I replaced the tailshaft bushing also.... its the rubber/metal thing at the end of the tail right?
Old Aug 3, 2008 | 09:45 PM
mattdel's Avatar
mattdel
i smell a bad tailshaft bearing
Old Aug 4, 2008 | 11:41 AM
ZoomZoom04's Avatar
ZoomZoom04
Definately the driveshaft. I have a 94 and did the same swap. The AOD has i believe an all steel driveshaft with counter weights on it which throws everything off when switching to the 5-speed. You need to get an aluminum driveshaft. I'd go with the ford racing one. Thats what I threw on mine and haven't had any problems since!
