starting problem
Old May 10, 2005 | 11:50 AM
stanglx2002's Avatar
stanglx2002
Default starting problem
In the mornings i will start the car and it will die but if i give some gas and let it warm up it will run fine. When it is warmed up i try and start it will will not fully turn over but try it again and i have to keep the key for a while then it will start. what is the problem?
Old May 10, 2005 | 02:30 PM
sastangman's Avatar
sastangman
Default RE: starting problem
what starter are you running
Old May 10, 2005 | 02:33 PM
stanglx2002
stock
Old May 10, 2005 | 02:52 PM
sastangman's Avatar
sastangman
as far as the morning starting giving it gas to warm it up is common
for modded stangs kind of the old hot rod feel. the starter sounds like
it might be crapping out "hot starting".dont go out and buy a expensive
hi-torque starter i have on my 90'coupe a starter from a 95' 5.0 it is
small kind of looks like a expensive one everything bolts up perfect
with no problems all the wiring is the same.
Old May 10, 2005 | 02:59 PM
grabbem88's Avatar
grabbem88
starter is heat soaking........just buy a powermaster like i did...$140 bucks i think and i got some hot a$$ L/T's from mac on there.
i like it...just hit it once and it's fired up
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
