Help me with this pinging problem
I have a 93 Mustang GT with a Vortech SQ-Trim and all of the usual goodies.
When mashing on the gas pedal (WOT) while on 5th gear from about 2800rpm , i hear what i believe is the engine pinging as the rpms increase.
This is only happening on 5th gear.
When racing through the gears with the gas pedal on the floor, no pinging is heard.
I've change spark plugs to 2 ranges colder, replaced with wires, checked timing - 10 degrees, cleaned the TB, cleaned the Idle Bypass valve, checked TPS- .95volts, cleaned the mass air sensor & tightened the header bolts... Still the same.
What could be the problem?
what kind of gas and how much boost are you running. in you highest gear while under load is when you usually get pining. try going to a higher octane fuel or even dropping down to 9* timing
for real..what psi?.... what plugs..and if you herd pinging while racing you'll be about 1 min from a new head gasket..the car needs tuned....I hope you atleast have a fmu or larger injectors
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
