EEC IV code help
Old May 11, 2005 | 04:46 AM
ddillard77's Avatar
ddillard77
Default EEC IV code help
I have a 91 5.0, 5 speed. I am getting codes 51, 22. 23. 54. 34. 67. and 82.
Which represent ECT, MAP, TP, ACT, EGR, NSS, and TAB. I have tested the ECT and ACT and the problem that the book I am using, How to tune and modify ford fuel injection, says is wrong is the signal return wire. The book lists it as a black and white wire that connects to the ECU on pin 46. My wire is grey and red and tests good with a continuity tester. This started when my car fried its computer and I replaced with a refurbished ford A9L. Any suggestions would be appreciated.
73mm C&L MAF
70mm BBK throttle body
Trick Flow Street intake
Mac shorty headers
Mac Cold Air
Flex-a-Lite electric fan
Stock injectorsBBK adjustable fuel pressure regulator
Old May 11, 2005 | 07:39 PM
90Mustangfan's Avatar
90Mustangfan
I ♥ Acer
Default RE: EEC IV code help
check the salt and pepper connectors right behind the intake manifold...look up the salt and pepper connectors at yahoo and youll find a ting on fixing the connectors...likley that your problem because all those things cant be tweaked...well mabye if your car is really messed up...which I doubt
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
firehorse02
Nov 16, 2015 11:28 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
