Another quick tech question:
Old Aug 17, 2008 | 08:38 AM
1984Fox's Avatar
1984Fox
Default Another quick tech question:
Alright, so when I put in my new motor, I'm swapping over to fuel injection. I'm doing this because I plan to boost the beast eventually.
I have almost all the parts I need, but I've heard I will need an inline fuel pump as well as a different gas tank?
Can someone confirm this?
Here's what I've got so far:
Upper/Lower intake manifold
Throttle body/Intake
Fuel rail/Injectors
Injector Harness
MAF (73mm)
Here's what I know I need:
Main wiring harness/ECU
What am I missing?
Thanks guys.
Old Aug 17, 2008 | 09:25 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if you car was a 84 carbed model and not the cfi model than you will need a different gas tank for one cause the efi model has an in tank pump and carrier and a fuel tank baffle set up that'll surround the efi pump so fuel slosh doesn't occur also the sending unit for the gauge is seperate from the fuel pump carrier on efi models and located in the center of the tank where as on the carb models the sending unit was located on the pick up tube assembley and a 1 piece does all unit
Old Aug 17, 2008 | 11:38 PM
1984Fox's Avatar
1984Fox
Ok cool. Yeah, my 84 is a carb'd model. Thanks for the info. Am I missin anything else??
Old Aug 18, 2008 | 07:12 AM
mjr46's Avatar
mjr46
nope looks fine
Old Aug 18, 2008 | 07:41 AM
AdderMk2's Avatar
AdderMk2
Banned
need an ECM, and all of the correct sensors, EFI distributor, new coil (TFI coil)
Old Aug 18, 2008 | 10:11 AM
FoxGT's Avatar
FoxGT
You don't need a pump in addition to the one in the tank, providing the one in the tank is a decent size. A 255lph should be fine unless you're looking for big numbers.
Old Aug 18, 2008 | 10:41 AM
mjr46's Avatar
mjr46
maybe true if he were efi!!! but he's converting from carb to efi so no pump in the tank so yes he does need an efi pump
Old Aug 18, 2008 | 11:16 AM
1984Fox's Avatar
1984Fox
Yeah, doin a full conversion. I've got the dizzy and coil, just forgot to put on the list.
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
