WHO HAS AFR 185's PEDESTAL MOUNT? LOOK INSIDE.
Old May 15, 2005 | 08:58 PM
grabbem88's Avatar
grabbem88
Default WHO HAS AFR 185's PEDESTAL MOUNT? LOOK INSIDE.
when i was at the world ford challenge. i visited the AFR stand,and we talked about my setup,and what i found out was although i kept my lift in check my duration is causing
me to valve float[:@]......i kept wondering why when i had it dynoed last year/this year.
my car fell off like a rock after 5500rpm....it was smooth until i reached that point.
the intake is a rpm,and the cam is a comp 276hr which was ranged at 2200 to 6200..
has anybody heard this? or experienced it? or did i talk with the wrong guy?
Old May 15, 2005 | 09:10 PM
Magiarn71's Avatar
Magiarn71
Default RE: WHO HAS AFR 185's PEDESTAL MOUNT? LOOK INSIDE.
Are the springs that you are using to the same spec as recommended with that cam? I know I'm going to use a xe274 and I have to swap the springs out of the 185.
Old May 15, 2005 | 09:24 PM
grabbem88's Avatar
grabbem88
i asked comp when i ordered...they said i should be fine[&:]...that was the first thing i told those guy's.
AFR said my ramp rate vs. there springs is hurting my performance..
Old May 15, 2005 | 09:54 PM
86HOGT's Avatar
86HOGT
Yeah, AFR even states on their website to use stiffer spring if you use more than such a lift and dur. I know a guy that built a 351W in his 86 and bought preassembled heads and the valve would float right at 6000. It almost seems like you need to put stiffer springs in preassembled heads..
Old May 15, 2005 | 10:01 PM
grabbem88's Avatar
grabbem88
AFR did say comp cams has a drop in spring,and they said some company by the name of flow tech induction??
afr said these guy's are really good,and have the right springs to drop in also.
Old May 15, 2005 | 10:42 PM
P.S.I.cho's Avatar
P.S.I.cho
ya flowtech is good im not sure if they make springs are not but they have good quality
Old May 15, 2005 | 10:48 PM
grabbem88's Avatar
grabbem88
i know they do custom cams that's all..
Old May 16, 2005 | 01:27 AM
grabbem88's Avatar
grabbem88
can anybody give any insight on this?
Old May 16, 2005 | 01:01 PM
C/Note's Avatar
C/Note
I ♥ Acer
well every time you float the valves they get weaker every time they float..you might want to pull you cover and check for broken inner spring ,my hyd roller in my truck was flat lining ,,i had 1 broken spring...but then i changed spring and went with solid roller cam ..more power..more gas....[] ..i should have down sized..[8D] i think that guys full of it ..i got 1.7 s and 700 lift ..and i got no probelms ..230 psi seat pressure...trucks got 205 psi..your spring are set out of your cam specs ,,right ,,hyd rollers sign off quicker ,,thats why i changed ..7800 or bust...
Old May 16, 2005 | 07:29 PM
grabbem88's Avatar
grabbem88
thanks 408....lol i guess there arn't too many gear heads on this forum anymore?????
