Almost Done
so i got all of the accessory drive put back on now all i have to do is get the high pressure line for the power steering, hook up the ram air from the hood to the throttle body, put a few hoses on, and figure out where all the loose ends from the wiring harness go....
if i cant figure out where something goes will anyone be able to tell me where something goes if i take pictures?
ok so someone who was woring on my car before i got it back looped two of the connections under the intake plenum together where should all of those be going? i dont have any of them hooked up anymore because i highly doubt they should be looped to eachother
i just don't know what you did to your car in the first place. Why were the accessories off? Are you fixing a problem, or upgrading? things like that. did you mess with the distributor? no one will be able to help you unless you give a detailed description of what you did to your car and the symptoms its having now
