Newbie please help
Old Sep 18, 2008 | 09:45 PM
outkastracing's Avatar
outkastracing
Default Newbie please help
well first off i new to mustangs, i bought a 93 lx auto with the 5.0 its in ok shape but has some issues for instance none of the guages work! the tach, water temp, oil pressure, fuel sender, nothing the speedo works but its mechanical... so i need to be pointed in the right direction here im very capable of fixing this with your help! thanks for the help
Old Sep 18, 2008 | 10:17 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Check the fuse for the gauges
Old Sep 18, 2008 | 10:20 PM
outkastracing
which one is that? i checked all the fuses and they all were good i found one that was bad it was the gauge lights replaced that and still nothing! is there a different set of fuses besides the ones on the driver side?
Old Sep 18, 2008 | 10:23 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Nope, sounds like it's time for a diagram
Old Sep 18, 2008 | 10:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
could have a bad ground to the cluster...like PRO says...you'll need a diagram
Old Sep 18, 2008 | 10:44 PM
outkastracing
that is what i was thinking does anybody make a aftermarket bezel that i could buy gauges and put in to fit the stock location
Old Sep 19, 2008 | 01:26 PM
taurus gt man's Avatar
taurus gt man
Im not 100% but there is a voltage regulator on the backside of the instrument cluster that might be the cause of your problem. Also there is an aftermarket company that sells a cluster that fits in the stock location and you fit your own gauges in from there but its not cheap.
Old Sep 19, 2008 | 05:08 PM
outkastracing
well ive been reading and reading and following wires so i got new gauges today and going to do a custom install tonight hopefully ill post pics tommorrow
Brett Ludlow
Sep 23, 2015 06:59 AM
Natex
May 10, 2004 09:43 PM
hewittpony69
May 8, 2004 08:42 AM
