intake install trouble
so yesturday i finished installing my typhoon intake manifold. i cant get me car to start, my battery was dead and i hoped that was the problem, but i got it charged today, its cranks good but its just doesnt want to start. i was just wondering if you guys can throw out some ideas as to what could be the reason as to why it wont start. i did remove the distrubuter and put it back in the same spot. as i crank it, it seems like its strugling to start, some times ill let off the key to stop the starter and the motor will have like 2% life in it, itll putter a bit and die.
but how do i time the car if i cant get it started, i think it is the timing isse though, i spun it abit then tried cranking it and it started to sputter more than before but its not there yet. should i use like quick start or put some gas in the throttle body
Note: it will be hard to turn the engine with all the spark plugs in & turn CLOCKWISE!
...Car will not start if you "quick start" it & Do Not add gas...you'll end up fouling the plugs!
k wow im so happy i got it start, i know the timing is off i can hear it, but its sounds so frickin BAD ASSSS wow. when i started her up some black smoke came out, then it start shoting out some white smoke. also when i roughly found a spot where it ran the best and reved it, the engine would stall out once the rpms settled down.
i put on the typhoon intake manifold, yea it sounds different for sure, and i think that once i get the timing done right i think the motor will be making some more power to. what could be causing the idle to die out after i rev it? could that be because of the timing
