Extreme Bucking
Old Oct 7, 2008 | 01:56 PM
Shelty's Avatar
Shelty
Default Extreme Bucking
drove out today for my internship interview, and the car gave me trouble the entire way there 20mi..
the car bucked at 60mph and would stall out at stoplights... needless to say it restarted every time it died...
it sat for 45 minutes whilst I met with the cheif of police to fill out paperwork etc...
drove home, not a single problem...
it goes to the shop on thursday, what should I have them look at? the car flashed code 91, but Ive been too busy to clean/replace the o2 sensors, and this is the first time I drove the car since sunday... and sunday it gave me no problems either...
I'm also a little fed up, so I dont want to deal with it right now... too much going on etc...
Old Oct 7, 2008 | 02:05 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
depends on if it's ignition related or what?? could be a tfi module or stator issue in the dizzy or a bad coil..ect ect......make sure the maf is clean also
Old Oct 7, 2008 | 02:07 PM
Shelty's Avatar
Shelty
thanks, I'll look at it or point them in the direction or something...
classes have me on my feet...
Ive been busy busy busy... bleh...
Old Oct 7, 2008 | 02:08 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
code 91? make sure there is no exhaust leaks before the o2's. make sure the o2's are screwed all the way into the bung. also if that doesnt work take off the small section of wire harness and clean the connectors, that cleared up the code 91 for me. there was a lot of corrosion on mine.
Old Oct 7, 2008 | 02:18 PM
Blckstng93's Avatar
Blckstng93
High miles? Id replace the o2 sensors but id wait to see what the shop says first. When was the last tuneup?
Old Oct 7, 2008 | 02:43 PM
Shelty's Avatar
Shelty
it was recently done, in the past two months I did the following
Oil change
New Plugs
New Wires
New cap/Rotor
New Ignition Coil
New Fuel Filter
and its got just under 131k on the odometer
Old Oct 7, 2008 | 05:59 PM
5.0stanger's Avatar
5.0stanger
I would check you batter cables, and all your grounds. Check you connections on your solenoid also.
Old Oct 7, 2008 | 06:21 PM
Shelty's Avatar
Shelty
I did forget to mention that I smelled Gas when it stalled...
I had the windows down
mungodrums
Oct 7, 2015 04:01 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
KingRando
Oct 1, 2015 11:16 AM
SteelerNation82
Sep 16, 2015 07:11 AM
M3hunter
Sep 5, 2015 03:42 PM
