Nitrous Boys lend me your ear!!!
Old Oct 7, 2008 | 06:07 PM
hillbilly pony's Avatar
hillbilly pony
Default Nitrous Boys lend me your ear!!!
Ok it is time to spray the ole beast....
Tell me what your opinions are on the 4150 spray bar kits vs perimeter spray kits. i have heard that perimeter kits make way better power and responsiveness. i can only imagine the increased CFM is disrupted due to the bar in the way..
What are your experiences
Old Oct 7, 2008 | 06:10 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the spray bar doesn't really affect it all that much, mine has no ill effects with such, the perimeter kits are suppose to have a more even dispersal rate but honestly my superpowershot kit works well, out of just a 100 shot I usually pick up 8-10 more mph and .7 to .9 more et, with a conservative tune
Old Oct 8, 2008 | 05:00 AM
hillbilly pony
The bar kits are defnitely cheaper. How do you have your fuel ran to the cylinoids? most seem to have -4 inputs but all of the regulators ive found only have -6 or bigger outputs. i was hoping to change to one that i could run 2 -6's to my carb and then have enought -4's to carry the fuel for the nitrous mix
Old Oct 8, 2008 | 06:51 AM
mjr46's Avatar
mjr46
the nitrous line to plate is -4an as well as the fuel line from my regulator to the selonoid which is sufficient..what ever kit you buy comes with the proper selonoid that'll flow the proper amount of fuel, depends on the size shot you run that determines line and selonoid,...there is no point in having -6an for a selonoid that was designed around the flow of -4an....think of the selonoid as a water gate, doesn't matter how big the line is behind it the selonoid can only take on so much volumne at once
Old Oct 8, 2008 | 06:56 AM
joeymustang's Avatar
joeymustang
my 4150 bar works well i guess...i ran 13.6 @ 101 n/a, with a 100 shot i got a 12.9 @ 112 so i don't think it looses much if any.
Old Oct 8, 2008 | 07:37 AM
hillbilly pony
Thanks Joey...numbers cant be argued with....
Mjr, i was meaning fuel lines from the regulator to the selonoid. i gotcha on the -4 for the supply to the plate im having a little trouble finding the right regulator to get fuel to the carb and the selonoid at the same time...im rambling...i need a reg with 2 -6 outputs and 2 -4 outputs. so if i decide to use a perimeter kit i need fuel to 2 solenoids. i dont run a splitter to my carb i run 2 individual lines from the reg to each bowl
FivePointToTheOh
Mar 9, 2020 10:26 PM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 16, 2015 03:07 PM
Roush05
Sep 10, 2015 12:23 PM
