Problem/question
Came home from work today in my 92 5.0 I hardly drive. Tried to start it and noticed she would turn over but not run. She was running close to E that day so I filled her up on 92 pump gas. Still not firing up. Occasionally she would fully crank but immediately turn back off. So assuming its the fuel pump I may purchase a new one and slap it in. Now if it is the fuel pump. I am expecting to purchase a supercharger sometime next year. And will need a performance fuel pump. If I buy A performance fuel pump and throw it into a completely stock car will I run into issues?
Surly I don't. I d her the electronic clicking, which is the starter engaging I'm guessing....And of course when It does fire up its only when I spray starter fluid into the intake. Either the starter pump or relay imo.
Yea surly. She's a sweet ride and I just got her. I do have an dumb question though. The fuel pump is located in the tank right? I was informed by a friend that the fuel pumps on most stangs are located in locations you would not expect. I never actually took the time to jump under the hood to get used to the guts of my car.
Here is what you need to know to change the pump.
I have heard they are easy to change but I haven't done it myself in the Fox. First you will want to drain the fuel tank. Then disconnect the battery, then drop the fuel tank, it has 2 bolts, 14mm? Not sure. Disconnect the lines, the power plug, then turn the metal ring that holds down the fuel pump assembly and carefully take out the fuel pump assembly. It has a positive and negative wire that goes to the pump, unscrew them, and then the pressure hose that goes to the pump. That should be it. Install in reverse order. As I said I haven't done it, just what I have been told.
FASTNYCMUSTANG
Aug 2, 2007 06:18 PM
