Factory fuel rail fittings
Old Oct 12, 2008 | 02:59 PM
justhereforinfo's Avatar
justhereforinfo
Default Factory fuel rail fittings
Im trying to remove the lower intake to do a head swap, and the fuel rail fitting that attaches to the fuel feed and return (from under the car) wont budge. I see they use clips to prevent the fuel line from popping off under pressure, so I removed the clips and tried to pull them off. They wont budge. Am I doing something wrong? I tried some PB Blaster but they're not popping off. Are they supposed to pull right off?
Old Oct 12, 2008 | 03:34 PM
crusin92red5.0's Avatar
crusin92red5.0
there are four screws that hold the fuel rail on, did you take those off? i didn't even take the clips off. just unscrew the 4 and the bolt holding on to the head and push to the side.
Old Oct 12, 2008 | 03:53 PM
Boss_Hotrod's Avatar
Boss_Hotrod
They are quick connects. You need a special tool to get them apart.
Old Oct 12, 2008 | 04:16 PM
ALMOST STOCK's Avatar
ALMOST STOCK
You can use the same disconnect tool as you do for your AC.
You can find these at most Auto Parts stores
Old Oct 12, 2008 | 04:24 PM
ALMOST STOCK
This might help also?
Old Oct 12, 2008 | 04:29 PM
Timspony's Avatar
Timspony
SVT Section Moderator
Good pics. ...fuel lines should come apart...If not I've got a fuel rail line 4 sale
mtgldr
Feb 3, 2024 09:00 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
zanemoseley
Sep 6, 2015 12:58 PM
