car problem....!?
i have an 89 mustang gt... i have been tacking various problems with this new car and it only seems to be getting worse!!!
I start the car it sounds fine but every time i sit at an idle and rev it up it it bogs down then revs.. like there is a delay... so i back out and put it in drive and it does the same thing almost at times seeming like its going to die!! Can someone PLEASE help me I have work tomorrow and this is my only transportation I need to get this thing running half way decent! THANKS!!
it could be the fuel filter, it if boggs like it is starving for fuel then it has a lack of fuel, but if it picks back up that could mean the filter is letting some fuel in and that is why it picks up, a filter it cheap and a 10min job if i was you i would do it, also clean fuel=better throttle response and more power, also get a fuel pressure gauge to mount onto your shrader valve, so you know if you have the right ammount of psi, if not then it could be the fuel pump, regulator, cloged fuel lines it is endless what it could be, try the cheap stuff first.
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
