D70EDA heads
Old Oct 23, 2008 | 09:01 PM
84_302's Avatar
84_302
Default D70EDA heads
thats the casting number of these heads i found for twenty bucks.. are those the 351 heads that will improve my 302? I remember only some kind of 351 heads help but not sure what ones
Old Oct 23, 2008 | 10:02 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
^^^^^^^^^yes dooe heads are comparable to gt-40 heads...but IMO they are only worth it if someone has lightly ported them and installed larger valves..I have c9oe heads on my 66 which are the same as DOOE heads
Old Oct 23, 2008 | 10:04 PM
84_302's Avatar
84_302
Well for 20 bucks ill pick em up... with me and my dremmle ill port em myslf and theyll be better than ever!!!
Kidding
Old Oct 23, 2008 | 10:11 PM
mjr46's Avatar
mjr46
cool, the dooe heads will raise compression slightly as they have a slightly smaller cumbustion chamber than stock e7 heads
Old Oct 23, 2008 | 10:17 PM
84_302's Avatar
84_302
i hvae 289 heads on it now... which is better the 351W or 289?
Old Oct 23, 2008 | 10:19 PM
mjr46's Avatar
mjr46
depends on which 289 heads you have?? the heart shape cumbustion chamber 289 heads will carry a higher compression than the dooe heads, so if those are the 289 heads you have, I'd port them and put larger valves in those if you can get it done cheap
Old Oct 23, 2008 | 10:21 PM
84_302's Avatar
84_302
i have to tear em off to check or will you kknow if I say they are from 1965?
Old Oct 23, 2008 | 10:27 PM
mjr46's Avatar
mjr46
no^^^^^^^^cause there were a few variations.......post a pick of them when you get them off of the combustion chambers and we can analyze them
Old Oct 23, 2008 | 10:31 PM
84_302's Avatar
84_302
haha will do gotta finish my c4 swap im in the middle of first though also another question i want to buy an engine to play with over the winter what year motors ( not like past 93) are the best to slap bolt ons too?
Old Oct 23, 2008 | 10:34 PM
mjr46's Avatar
mjr46
any roller block set up from like 85 -92 will be fine as those are the years that had forged pistons stock, as far as power output between the years, not much difference
