Keyless entry
Old 08-05-2013, 06:59 PM
95 gt 5.0
95 gt 5.0's Avatar
Default Keyless entry
I have a question for the forum pros. I have a 95 vert, looking to install a factory keyless entry system. I believe I have the wiring already in place in the trunk, if I find the module that goes in the trunk, and a couple of fobs, is at all I will need. It does have power locks. Thanks.
95 gt 5.0 is offline
Old 08-05-2013, 07:27 PM
dawson1112
dawson1112's Avatar
It is already equipped with keyless entry if it has power locks.
Does your cars interior light come on when the doors are locked and you pull the door handle? If so you have the keyless entry .
My 94 is in the trunk behind all the plastic on the drivers side .. I had to jump a set of wires on a plug back there to program my remote.
1995 Mustang
1. Turn ignition to RUN or ACC.
2. Momentarily jump pins in programming connector located in LR quarter panel area (Connector will not be plugged into anything, it will have two pins inside it, if you have to unlug it you have the WRONG one. Not all vehicles are set up from factory for keyless remotes) All doors will lock then unlock to confirm programming mode.
3. Press any button on first keyless remote. Door locks will cycle to confirm programming.
4. If programming a second keyless remote, press any button on second keyless remote.
5. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Look in the LR quarter panel of the trunk for this plug and momentarily jump the 2 prongs I have indicated with a black jumper.
At least that's how I programmed mine I didn't even know I had that feature till the guy up the street told me about it and gave me a key fob and showed me how , he worked at ford for years building the mustangs.
dawson1112 is offline
Old 08-05-2013, 07:32 PM
Duncan_GT
Duncan_GT's Avatar
^^I'll be damned. I didnt know that
Duncan_GT is offline
Old 08-05-2013, 07:45 PM
dawson1112
dawson1112's Avatar
lol and the funny part is it was an option. Most people that didn't choose that option still had the keyless entry just didn't get the Key fob . All they would have to do is get any ford key fob for that model and program it.
Old 08-05-2013, 08:08 PM
95 gt 5.0
95 gt 5.0's Avatar
Good to know, I'll have to try that. So what is the control box in the trunk for then?
Old 08-05-2013, 08:22 PM
dawson1112
dawson1112's Avatar
What control box?
Are you talking about the fuel inertia switch , or maybe the amp for the factory stereo??
Old 08-05-2013, 08:39 PM
95 gt 5.0
95 gt 5.0's Avatar
How can I post a pic in here? It sits on the LR quarter, about 6inches in front of the fuel switch. Not the amp for the radio
Old 08-05-2013, 08:51 PM
dawson1112
dawson1112's Avatar
I use photo bucket to upload pics to then , when the imige is uploaded use the img code to the right and click it it will copy it to your clip board. THen you can paste it into the comments of your post
Old 08-05-2013, 09:02 PM
95 gt 5.0
95 gt 5.0's Avatar
Here is a picture of the bracket that holds the module, and I believe that is the module in the bottom of the picture. http://i838.photobucket.com/albums/z...1f71e4f0e9.jpg
Old 08-05-2013, 09:04 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
ill have to look to see if the GTS has this in the trunk
rmodel65 is offline
Quick Reply: Keyless entry
