Rear Control Arm Bushings
Old Nov 23, 2008 | 05:35 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Default Rear Control Arm Bushings
I have been looking at new rear control arm bushings and latemodel sells both round and oval poly urethane bushings. What would be better to get? Mainly for street driving but you know for the occasional track too. Using these on top of boxing my control arms should help plant that power to the ground.
Old Nov 23, 2008 | 05:43 PM
crusin92red5.0's Avatar
crusin92red5.0
lower control arms right? cuz your not suppose to use poly urathame on the uppers
Old Nov 23, 2008 | 06:06 PM
projectresto83
M.A.D. Motorsports
Yea thats what I would be going for. What would you guys recommend for bushings the uppers? I have heard a few combos but I can't remember them right now.
Old Nov 23, 2008 | 07:07 PM
primetime5.0's Avatar
primetime5.0
on the axle side im using ford bushings, on the body side whatever upr sells with there control arms
Old Nov 23, 2008 | 07:23 PM
ctgreddy's Avatar
ctgreddy
don't use poly bushings on the axle side. i just bought new ford bushings. and you may want to buy the install tool from mm if doing this, makes it 1000000x's easier.
Old Nov 23, 2008 | 07:42 PM
projectresto83
M.A.D. Motorsports
I have heard sphericals word great on the axle side
Old Nov 23, 2008 | 08:17 PM
primetime5.0
if you wanna chew up the boxes definetly
Old Nov 23, 2008 | 09:11 PM
projectresto83
M.A.D. Motorsports
Is it the body side then? I can't remember which. I know I have heard good things about FRPP upper control arms.
Old Nov 23, 2008 | 09:35 PM
symonds86's Avatar
symonds86
not tryin to highjack but why not
Old Nov 23, 2008 | 10:14 PM
projectresto83
M.A.D. Motorsports
Causes binding and thus can cause bad wheel hop
Again what about the difference between the oval and round rear lower control arm bushings? Which is better for what?
From what I have seen sphericals can be a bit noisy but are used on both ends on the uppers. It depends on the brand. But since I am gonna stay with the stockers for now I guess just new ones from ford for both ends will work great? Then polys for the lowers.
