removing center console
In my 86, which is a bit different, took the shifter **** off, shifter boot, and I think there were a total of four screws holding it to the foor board. Looks so good without a console, I was thinking of gettng a delete kit...
Lift up the shifter bolt and there should be 2 screws under there in the front.
Then remove the oval covers on both sides at the back of the console.Then remove the 4 screws holding the armrest into the console.Then remove the arm rest and there should be 2 more screws under it.Then it should lift off.You will have to unplug the lighter.
after you do the step above you will need to remove the lower cover off the steering wheel and open up the glove box door. ther is like 4 screws there also need to remove the radio to get that rest of the console out
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
