vibration problems
Old Nov 29, 2008 | 06:50 PM
FORD TOUGH's Avatar
FORD TOUGH
well if it only vibrates at 60 with the clutch pushed in it cant be engine related. You may want to check your axle like port master said. It could also be a bent yoke on the rear differential. Is it making any noises and how bad is the vibration?
Old Dec 1, 2008 | 10:23 AM
lmatt's Avatar
lmatt
No noises. One thing I forgot, it still has the same vibration without the brake drums on. We have checked the yoke at the diff with a dial indicator, no problem. We have also checked the axles with a dial indicator. 60mph is just where the vibration starts. Ii just gets worse faster.
Old Dec 1, 2008 | 11:38 AM
Stella94GT's Avatar
Stella94GT
i have the same probablem, at the same speed. i dont have drums obviously but i replaced my rotors and pads and still have that same problem. i also know its not my engine mounts because when i installed my long tubes, i tightened them back down to spec. i was thinking its my driveshaft but you said you swapped yours out and nothing changed..
Old Dec 1, 2008 | 11:49 AM
FORD TOUGH's Avatar
FORD TOUGH
Do you still have the dogbone on the differential?
Old Dec 1, 2008 | 01:42 PM
cch's Avatar
cch
My uncle had a similar problem with his 92 hatch. After he changed his t5 to a tko600 there was a nasty vibration after 60. We checked and dialed everything but couldn't figure it out. Eventually he wound up putting a carbon fiber drive shaft and hasn't had a vibration since. Good luck!
Old Dec 1, 2008 | 04:04 PM
nseoi's Avatar
nseoi
i know u said u replaced the driveshaft but did u check the U joints? my car had the same vibration, it would make your skeleton shake if you held the shifter. all i did was check my U joints and sure enough they were about to grenade. swaped out the whole yoke, u joints, and driveshaft, with the ford racing aluminum one
Old Dec 1, 2008 | 04:12 PM
Portmaster's Avatar
Portmaster
Pull the driveshaft ount and check the U-Joints. You could have a bad one and that will sure cause the vibration. Also check the driveshaft for a missing balance weight. My money is on the joints. If you replace them do them both.
Old Dec 1, 2008 | 04:13 PM
Portmaster's Avatar
Portmaster
Sorry I was lagging behind you when I posted
Old Dec 1, 2008 | 04:47 PM
lmatt's Avatar
lmatt
No dog bone. Swapped the driveshaft with a different one out of a mustang that doesnt have the vibration problem. Didnt change anything.
Old Dec 1, 2008 | 04:50 PM
lmatt's Avatar
lmatt
Could the mph not have anything to do with my problem? I have only used that as a place to relate the issue to. Different rpm's dont change the vibration as long as the mph's are above 60. Thanks for any and all ideas. I will take anything I can get.
