ROUGH IDLE
Old Dec 30, 2008 | 05:36 PM
TexasHotrod's Avatar
TexasHotrod
Question ROUGH IDLE
I post a couple of months ago about my rough idle problem, I have since changed the ACT, TPS,IAC cleaned TB cleaned injectors and my fuel pressure is 30 PSI does anyone have any suggestions???? and also cleaned the MAF
Old Dec 30, 2008 | 05:56 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
check for vaccum leaks and make sure all cylinders have proper compression
Old Dec 30, 2008 | 06:06 PM
TexasHotrod
no vac leaks but I havent checked the compression wat should the compression be?
Old Dec 30, 2008 | 06:17 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
If there is an egr valve on the car make sure it's working correctly and not sticking open. There should be no vacuum going to it at idle. The f/p should be set around 39psi.
Old Dec 30, 2008 | 06:25 PM
TexasHotrod
yes that works correctly, and I was told when car is running it should be 30, and when koeo it should be 35-45psi
Old Dec 30, 2008 | 06:34 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
30psi is too low while running at idle. How does the car run otherwise under cruise and load conditions?
Old Dec 30, 2008 | 06:39 PM
TexasHotrod
It runs good when driving or hitting the throttle its just the idle thats jacked up it is really irritating the **** out of me
Old Dec 30, 2008 | 09:12 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
OK, so has it always been like this?
Have you changed something and then it started?
What's your mod list?
Old Dec 30, 2008 | 10:11 PM
nasty90's Avatar
nasty90
Are you sure you dont have a nasty cam? LOL J/K
Old Dec 30, 2008 | 10:16 PM
FORD TOUGH's Avatar
FORD TOUGH
how did you check for vacuum leaks?
