Cooked Engine???
Old Jan 2, 2009 | 11:41 AM
painistruth302's Avatar
painistruth302
Default Cooked Engine???
Alright here is my scenario.... I got off the highway, heard a squealing coming from under the hood, I stopped at a gas station and when I got out of the car I realised how loud the squealing actually was. I drove the car about .5 mile to my house and parked it for the night. I went out the next day in the light and popped the hood to find nothing wrong visibly.. (thought it was the belt) I tried to start it. The car wouldnt turn over at all, gives a clank and a spinning sound when I turn the key. I checked the starter, and pulled off the belt to see if one of the pulleys were stopping the car from starting. Is my engine cooked or what?
Old Jan 2, 2009 | 11:44 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
TRY AND ROTATE THE MOTOR over by hand = put a 15/16 socket and 1/2 drive down on the crank pulley and see if you can rotate it fully...that'll tell you if motor is locked up.
Old Jan 2, 2009 | 11:46 AM
gtmustang1090's Avatar
gtmustang1090
honestly the noise sounds like ur alternator might have had a bearing inside go.. that would possibly explain the clank to when ur trying to turn that.. i dont think anything is wrong because you wouldnt have really been able to drive it anymore if it seized .. just my opinion
Old Jan 2, 2009 | 03:06 PM
FORD TOUGH's Avatar
FORD TOUGH
Does it have oil in it? Was it running hot? Try turning it over like MJR46 said. If is a 5 speed you need to have it in neutral and the parking brake drawn and the wheels chocked.
Old Jan 2, 2009 | 03:27 PM
Portmaster's Avatar
Portmaster
Sounds like it spun a bearing. I hope I'm wrong
Old Jan 2, 2009 | 06:45 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
A clank and a spinning? Was it a high speed spinning noise? Sounds like your starter may have engaged while you were driving and got so hot that when you shut it down and let it cool it seized up inside its housing. A starter that is engaged when the motor is spinning gives a nasty whine. I know that from experience.
Pull your starter off and get a set of jumper cables and jump it to see if the gear comes out and spins like it normally would.
Old Jan 3, 2009 | 08:55 AM
Timspony's Avatar
Timspony
SVT Section Moderator
I had a smog pump sieze once (nothing would turn)...thought it was the engine!
Old Jan 3, 2009 | 11:16 AM
silver91gt's Avatar
silver91gt
me too, thats when i deleted mine
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
