motor mounts
Old 05-19-2005, 07:13 PM
philthy89fifty
philthy89fifty's Avatar
Default motor mounts
i tried to search but came up empty. so can someone walk me through how to change my motor mounts? i went with solid cause i got them cheap heres a pic of them. please help me out.
[IMG]local://upfiles/14210/3AFA075828974B9EB013C026D14F94C1.jpg[/IMG]
philthy89fifty is offline
Old 05-19-2005, 08:15 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: motor mounts
you f'ed up on that...hope you have a dental plan
vfast is offline
Old 05-19-2005, 08:54 PM
tomabram
tomabram's Avatar
ORIGINAL: vfast
Thats funny.
tomabram is offline
Old 05-19-2005, 10:19 PM
philthy89fifty
i know you feel the motor more but i like that
Old 05-19-2005, 11:45 PM
mkspeed26
mkspeed26's Avatar
just motor mounts, or both engine and tranny? basically, get the front of the car a good bit in the air on jack stands (enough to crawl underneath both from front and side). unbolt the bolt on the back of the k-member on both engine mounts. loosen the bolts in the back that hold the tranny mount to the crossmember. get a jack on the oil pan (use a block of wood to distribute weight) and jack the mounts out of the holes in the crossmember. unbolt the mount from the block, drop the new one in, reverse order to assemble. note: mounts are different left and right. make sure you get the right one on. you may need to remove or loosen other things in the engine compartment that would interfere with the lifting on the engine. my engine compartment is gutted (as in pic) so i didnt have that prob. also, my headers weree off. you amy need to mess around with extentions and swiver joints to get at the bolts to the block.
mkspeed26 is offline
Old 05-20-2005, 12:15 AM
philthy89fifty
thanks alot .
Old 05-20-2005, 03:48 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: philthy89fifty
You'll do more than just feel the motor more. It will tweak your frame if you jump on it often unless you have subframes. You may also experience torquing..where your left tire will lose traction on take off due to the motor turning.
Derf00 is offline
Old 05-20-2005, 04:12 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
ORIGINAL: Derf00
Maybe if he had a ton of HP and the car hooked real well, and it's the right rear that will always have less traction reguardless of what motor mounts you use.
*edit* I reread this and saw it was the wrong rear tire we were talking about
JD1969 is offline
Old 05-21-2005, 01:45 AM
philthy89fifty
i have 3.55 gears and traction lock. and i know i need subframes asap just i'm so broke i can't even afford those.
Old 05-21-2005, 03:56 AM
94Cbra
94Cbra's Avatar
Your gonna rock your tranny unless you brace it up too.
94Cbra is offline
Quick Reply: motor mounts
