alternator problem
Old Jan 22, 2009 | 04:49 PM
AYEOH5.0's Avatar
AYEOH5.0
Default alternator problem
the ammeter in my car jumps back and forward depending on how much im on the gas. at WOT it will charge around 13v normal but at idle it sits around 8v. i pulled my alternator and got it tested at autozone and they said its fine. what could be causing this? the serpentine belt is brand new also so i dont think its a slipping problem. someone said it could be a electrical connection grounding out somewhere?
Old Jan 22, 2009 | 05:09 PM
91lx50udlose's Avatar
91lx50udlose
Take a volt meter and check it with the engine not running you should have battery voltage then crank the car and let it idle check it again and see the voltage should go up a volt to a volt and a half should be 13 or a little more
then rev the engine some and hold the rpm's at 2 or 3000 rpms it doesnt matter and see if the voltage is still around 13v or a little more
If this is not what happens you probably have a bad alternator if this is what happens then it is good and you have a problem with the guage or something
Old Jan 22, 2009 | 08:36 PM
Modular_Madness96's Avatar
Modular_Madness96
Have you tested the battery?
Old Jan 22, 2009 | 09:02 PM
AYEOH5.0's Avatar
AYEOH5.0
battery is pretty much brand new, the battery voltage stays the same when the car is off or at idle. it goes up when on the gas. Autozone said the alternator is fine.
Old Jan 22, 2009 | 10:13 PM
Jerome99's Avatar
Jerome99
I have had a battery go bad after a couple of months
Old Jan 22, 2009 | 10:28 PM
AYEOH5.0's Avatar
AYEOH5.0
it was doing this before we bought a new battery. i believe it might be a short somewhere but i dont know where to begin looking. also, i dont know if this has anything to do with it, but if my gas light comes on when im low on gas, turning my heat on will cause the light to go off and when i turn my heat off the gas light comes back on.
Old Jan 22, 2009 | 10:29 PM
FORD TOUGH's Avatar
FORD TOUGH
Do you have underdirve pullies? Is the belt slipping? You could have a bad tensioner. Have you check with a volt meter to see how may volts you are charging?
Old Jan 22, 2009 | 10:35 PM
AYEOH5.0's Avatar
AYEOH5.0
i dont know if the car has underdrive pulleys or not, it had many mods on it the seller didnt know about. the tensioner seems fine though since ive had to take the belt off to replace it and also get out the alternator to get it tested.
is there any way for me to tell if it has underdrive pulleys or not?
Old Jan 22, 2009 | 11:03 PM
FORD TOUGH's Avatar
FORD TOUGH
look and see if the crank pulley is way smaller than the balancer.
Old Jan 22, 2009 | 11:33 PM
AYEOH5.0's Avatar
AYEOH5.0
okay its too late tonight, i will check in the morning.
