Oil Filter Relocation Kit
Old Jan 28, 2009 | 09:38 PM
Chaoss84GT50's Avatar
Chaoss84GT50
Default Oil Filter Relocation Kit
Does anyone know of a good oil filter relocation kit for the 302? I have an '84 mustang and I hate getting oil all over the place under car. I just have to clean it up and thats a pain. I found one on Jegs for $60 but it said universal. Will that work for my application? Any suggestions would be most appreciated, thanks for your help in advance.
Old Jan 28, 2009 | 09:50 PM
SonicBlueFiveSlow's Avatar
SonicBlueFiveSlow
http://store.summitracing.com/partde...5&autoview=sku
That will work and it's only 35.
Old Jan 28, 2009 | 10:15 PM
luckythirteen13's Avatar
luckythirteen13
Originally Posted by SonicBlueFiveSlow
thats similar to what i have. my oil filter is now inside the fender pointing straight down. no more drips
Old Jan 28, 2009 | 11:55 PM
Chaoss84GT50
last question, can I mount the oil filter so it points straight up on the inner fender well? will there be any leaking or any problems with the oil pumping straight up? thanks again guys
Old Jan 28, 2009 | 11:58 PM
SonicBlueFiveSlow
I think mounting it straight up will put more strain on the oil pump because it has to pump the oil up through the filter.
Old Jan 29, 2009 | 12:07 AM
Chaoss84GT50
so should i mount it low on the firewall? where do you suggest to mount and should I aim the oil filter straight down?
Old Jan 29, 2009 | 12:15 AM
SonicBlueFiveSlow
Just mount it wherever you have room and are able to access it fairly easy and yes, aim it straight down.
Old Jan 29, 2009 | 12:18 AM
Chaoss84GT50
hey thanks, looks like ill be picking that up this weekend and have it time for next weekend. Thanks
Old Jan 29, 2009 | 12:28 AM
SonicBlueFiveSlow
No prob, bob.
Old Jan 29, 2009 | 01:33 AM
luckythirteen13
are you serious, that is the stupidest way you could possibly mount it. it wont leak or strain the pump but as soon as you do an oil change, when you start threading the filter off, all the oil in the filter will dump out all over your hard and your driveway. also, its a smart idea to put some oil in the filter when doing an oil change so the first start up isnt dry. with the oil filter mounted with the opening facing down, this would be impossible.
here is mine
