what heads to go with now! just switched to carb
well i just swapped my engine to carb i got a 670 avenger and a rpm intake, with all msd ignition, and i have a holley cam in there with .509 lift out of the systemax kit, so my heads i had are garbage now so should i go with some patriot heads or edelbrock rpm heads for the price?
cam specs are advertised Duration (degrees) 276 280
Duration @ 0.050” (degrees 221 223
Valve Lift (inches) 0.509 0.509
Lobe Separation Angle (degrees) 112
Opens (degrees) 3.5 BTDC 48.5 BBDC
Closes (degrees) 37.5 ABDC -5.5 ATDC
so you think afr or tfs over the edelbrock rpm heads for sure eh?
The edelbrock head is an "ok" head but isn't all that but with the cam and intake set-up would work fine. For the same money you can get into a TrickFlow head that is a much better design. If you plan on sticking with your cubic inch, cam and induction I think the AFR 165's would do great as well. If you plan on putting some extra stroke to it in the near future I would move into a larger head such as the AFR 185 or 190 TrickFlow. The Edelbrock RPM eXtreme is a super head but for the kind of money they go for there are better options. I'd also advise you to skip the Patriot heads.
