Running problems
Old Jun 14, 2005 | 01:04 PM
fordfanjoe1982's Avatar
fordfanjoe1982
Default Running problems
I just did a motor swap. I have an 88 mustang gt, and the motor went bad. I took the motor out of an 89 lx. i did not swap the computers or anything like that. I am having a hard time starting the car now, especially when its warm. it almost feels like a dead battery problem, but the battery is fully charged....and now all of a sudden, the car stalls out, and runs like crap...crap meaning, it misfires, and has no power.....anybody know whats going on????
Old Jun 14, 2005 | 03:05 PM
fordfanjoe1982
Default RE: Running problems
i hope some of you more experienced guys out there can give me a word of advice......any would be appreciated
Old Jun 14, 2005 | 06:11 PM
Grey Fox's Avatar
Grey Fox
Did you swap out just the longblock, no electronics? Because the 88 is SD and the 89 is MAF and the wiring is a wee bit different and can cause issues when swapped out if you don't pay real close attention.
Old Jun 14, 2005 | 07:18 PM
fordfanjoe1982
i swapped the longblock....not computer, pretty much just plug and play....new clutch and hardware.....should i switch computers and convert to MAF? is that whats causing my hard starting especially when warm....and now it seems like its backfiring and running rough.....
Old Jun 15, 2005 | 03:45 AM
Grey Fox's Avatar
Grey Fox
I think, but I'm not 100% sure, that if you left the 88 wiring harness intact that you should be OK with that. Check to make sure that when you put the distributor in, it was lined up correctly.
Old Jun 15, 2005 | 06:16 AM
91LXstanger's Avatar
91LXstanger
backfiring is a timing issue and the sd and maf problem WOULD cause rough running problems. I swapped my 91 motor for the FRPP 306ci motor and im still having problems similiar to yours. U have to tune the computer for the new engine to get rid of the problems for good. Some other guys will say " u gotta do this and that" and blah blah. But the computer is designed for the speed density, not mass air. So get someone to mess with ur EEC. Or go one ebay and find the right computer.
Old Jun 15, 2005 | 12:12 PM
Ezrider's Avatar
Ezrider
the hot start problem is probably timming, running high advance will cause the motor to crank slow when the motor is hot
Old Jun 15, 2005 | 01:30 PM
fordfanjoe1982
i have the computer from the 89 car, and all the components....should i just go swap the computers and see what happens? keep the timing at 14BTC? im changing out the coil and the selenoid...plus the starter today.......
Old Jun 16, 2005 | 06:06 PM
fordfanjoe1982
i messed with the timing, but no matter what i do, it still cranks slow when its warm....changed the starter, selenoid, plugs, wires, cap, rotor......i can't figure it out.....should i do a compresion check? any help on why this thing cranks and runs like crap would be much appreciated
Old Jun 16, 2005 | 06:39 PM
stanglx2002's Avatar
stanglx2002
have you cleaned these parts:
MAF
TB
PCV screen
IAC
Replace:
PCV valve
fuel filter
Run a bottle of fuel system clean such as Sea Foam and get 2 bottles to clean the whole car. What did you set the timing back at?
