Help Please!!!!!!!
I own a 94 GT and have almost finished my motor build. The only thing im having trouble with is my aftermarket valve covers. Im installing a Trick Flow intake manifold, and since i have a 94-95 i need an intake elbow adapter. Using this adapter causes the bottom of my egr to hit my vavle covers, and the elbow adapter is aiming my intake right into my oil filler neck. So i need to know if the stock valve cover will fit over 1.6 rr's, because the stock covers will clear the egr and elbow, but i dont know if they will fit over the rr's. But if that doesn't work i was wandering if i could use an 87-93 intake setup from air filer to all the way to where the throttle body meets the manifold. If anyone has run into this problem before, or knows how to fix it, please let me know. Thanks
