problem??
Old May 6, 2009 | 01:46 PM
KG(94/GT)'s Avatar
KG(94/GT)
Default problem??
just got a 94 gt, it overheated on me and not sure what the problem is.
the oil level is twice as high as the fill line, it wont start. my friend thinks its a blown head gasket.
any ideas?
Old May 6, 2009 | 01:51 PM
Mike516882's Avatar
Mike516882
Drip the oil onto a paper towel if there is a ring around the oil drip its gas or collant, and most likely the head gasket...or smell the oil and smell for gas/collant... im guessing head gasket as well..
Old May 6, 2009 | 02:02 PM
briantlucas's Avatar
briantlucas
sounds like a head gasket how fun lol!!!
Old May 6, 2009 | 02:04 PM
KG(94/GT)'s Avatar
KG(94/GT)
thats exactly what my friend told me to do haha. the oil is on the thinner side and not sure about the smell, so either gas is in there or coolant
Old May 6, 2009 | 02:42 PM
95 madness's Avatar
95 madness
Won't start as in turns over or it doesn't turn over if it doesn't turn over you might have a hydrolock going on and it is not a good thing to try to turn it over usually the oil becomes milky if there is coolant in it. also if it is fuel that is bad becasue it will turn your oil into a stripping agent ( usually washing out the bearings and cylinder walls). Pull the plugs as well check each cylinder you will find the cylinder or cylinders where it has blown guaranteed. Sounds like no fun to me either way good luck.
Old May 6, 2009 | 05:53 PM
KG(94/GT)'s Avatar
KG(94/GT)
haha thanks man, ive been literally depressed. i checked the cylinders and spark plugs they are all good. and it doesnt turn over at all it just clicks :/
Old May 6, 2009 | 06:58 PM
1fast5OH's Avatar
1fast5OH
ruh roh, it may be locked up good luck with it, i've had my fair share of problems with my car so i feel for you.
Old May 6, 2009 | 09:22 PM
Ninety5five0's Avatar
Ninety5five0
I just hydrolocked my motor....Not a fun time. Take out all the plugs and put a 15/16" socket on the crank and try to turn it.... Make sure its not in gear....
Old May 7, 2009 | 01:36 AM
KG(94/GT)'s Avatar
KG(94/GT)
ill definitely try all of that, tomorrow is the day of reckoning haha
i only got to drive it for 2 days, god damn :/
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
