Wont idle!
Just put a bbk ssi intake on my 91. When i turn the key it takes a couple of turns and some feathering of the gas... or it will die. If i turn the key and not do anything the rpms go up and down, from .5 to 1.5, then dies. After i take off and drive it around at stops it wants to give out and die, but wont. Any ideas?????
im pretty sure i got all the plumbing right underneath the intake, but ill double check that. theres a one inch spacer in between the lower plenum and upper, so maybe it didnt seal right, ill have to check that 2. thanks for the advice...
i put a spacer on my cobra intake about a year ago and was having a problem too. make sure theres no vacuum leak from the intake. if you hear a hissing then spray some starting fluid to pinpoint it. mine was between the lower intake and head. pain in the @ss. good luck.
