will this work?
Old May 10, 2009 | 05:19 PM
symonds86's Avatar
symonds86
Default will this work?
will the belt routing work? i searched the forum but didn't find anything like the way im thinking.
Old May 10, 2009 | 08:51 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
will the water pump still spin in the same direction as it does with factory routing, that'll be the key
Old May 10, 2009 | 08:53 PM
symonds86's Avatar
symonds86
hmmm i donno i guess i gotta figure out which way it went, and which way its goin it my mock up
Old May 10, 2009 | 09:09 PM
mjr46's Avatar
mjr46
look at a stock belt routing then crank the motor over paying attention to direction of rotation and there will be your answer
Old May 10, 2009 | 09:59 PM
symonds86's Avatar
symonds86
pretty sure its not gonna work, back to the drawin board
Old May 10, 2009 | 10:04 PM
mjr46's Avatar
mjr46
what is your set up?? heads, block , cam?? ect ect....just curious, can't tell from the angle of the pic
Old May 10, 2009 | 10:08 PM
symonds86's Avatar
symonds86
302 mexican block w/ probe 347 kit, CI cam, canfield 195 heads with some work done to them by CI, comps "gold" 1.6 rockers
that pic just dont look right at first lol
Old May 10, 2009 | 10:31 PM
mjr46's Avatar
mjr46
I could of swore I've seen the belt set up run like that before on some rides , only most weren't using the tensioner, but a threaded rod to adjust tension on belt
Old May 10, 2009 | 10:40 PM
primetime5.0's Avatar
primetime5.0
looks fine to me
Old May 10, 2009 | 10:41 PM
symonds86's Avatar
symonds86
im pretty sure it makes the WP spin the opposite way of a stock set up
