vortech question
Old May 20, 2009 | 07:05 PM
Gator's Avatar
Gator
Default vortech question
I have a 90 lx 5.0 and i am getting the vortech kit from summit racing http://store.summitracing.com/partde...5&autoview=sku
The kit comes with a FMU, I am thinking of getting 30lb injectors, and maf to match, and 255lph pump.
If i run that setup will i need to run the FMU?
Do you think the 30lb injectors will be enough.
this kit is the low boost 5-6psi. and will run it that way for probly a while, untill more money is avalible.
__________________
Old May 20, 2009 | 07:53 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
I don't care for FMU's. I run a regulator and let it raise the fuel psi witht the boost. 5-6 psi is pretty low, so I think the 30 lbers would be fine.
Old May 20, 2009 | 09:46 PM
90_Mustang_GT's Avatar
90_Mustang_GT
With the 255lb/hr and and injectors you will be fine. Wouldnt be a bad idea to bump up to 42 lb. injectors though.
Old May 21, 2009 | 07:03 AM
92tealcp's Avatar
92tealcp
Default Boooooost
Just make sure you use a boost referenced pressure regulator. Bosch is the best one. 30lb with no FMU is what I am running with a 255 and an external pump as well. I am running 10lbs of boost that is why I am running the 2nd pump.
Old May 21, 2009 | 07:57 AM
Gator's Avatar
Gator
Im, wondering where you got your bosch boost ref. fpr?
and if you are running a dyno tune?
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
