Changing oil pan gasket?
Put my car on the lift at work last night. Noticed oil pan gasket looks like its leaking from everywhere. I've heard this is a very common problem. I've already purchased the the rubber gasket from felpro. I can see i'm going to have to unbolt the motor mounts and tranny mounts to lift the engine and I should be good after that right? I want to take the pan all the way out so I can run it through the parts cleaner to get out any sludge that's in there. The book says this should take about 4 hours...fo real?
Do I need to do anything else besides what I wrote above?
Thanks
Thanks
I know Haynes makes a repair manual for our style mustang. I actually had it in my hands when I bought the oil pan gasket but I didn't buy, why I don't know
oil pan
pull the P/S rack off the ears, remove the knuckle, lossen the front k-member bolts, remove the rears, unbolt the motor mounts, lower the k-member as far as possible without it falling down,remove bell housing cover plate, remove the oil pan. Install is reverse. It takes me 2hrs out and in.
