Oil in Upper
Old Jun 2, 2009 | 10:34 PM
calinotch's Avatar
calinotch
Default Oil in Upper
I took off the upper intake today to paint it and i found some oil in it. Is this natural? Whats the problem if its not? Also there werent any gaskets between the upper and lower only black permetex. Im guessing this is set up wrong and i should buy some real gaskets.
Old Jun 2, 2009 | 10:54 PM
mustangsneverdie's Avatar
mustangsneverdie
most likely it's just oil coming from your crankcase breather and/or your pcv valve
Old Jun 2, 2009 | 11:36 PM
08 Bullitt 2310's Avatar
08 Bullitt 2310
You are going to want a gasket between the upper and lower.As far as the oil,Make sure that the breather filter below the PCV valve is in good order or it will push oil into the TB and eventually shove gaskets and seals out.
Old Jun 3, 2009 | 12:01 AM
calinotch's Avatar
calinotch
yea i plan on putting gaskets on it now. where can i get a PCV screen if its not in the intake?
Old Jun 3, 2009 | 12:42 AM
08 Bullitt 2310
Most of your better auto parts stores carry them now.Used to be a dealer only item.I found the thing years ago after an oil pan gasket install and what looked like a non-functional PCV system kept it trying to shove things out.The dealership asked me how I found it when I asked for one.Nice huh?
Old Jun 3, 2009 | 06:38 AM
92tealcp's Avatar
92tealcp
Default oil blowby
Funny that when most guys do a rebe on the motor or intake swap they always forget to replace the PVC screen at the bottom of the PVC opening. I can't count how many times a customer brought a car into my shop complaining about oil blow by and other shops told them they need the motor rebuilt because they thought they had bad rings when it was only missing the PVC screen. I wonder how many 5.0 owners pulled the motor before they found this 6$ part missing and causing all the oil problems.
Old Jun 7, 2009 | 07:46 PM
calinotch's Avatar
calinotch
okay finally got a chance to look at it. the screens in there and doesnt look bad. how do i know if the PVC valve is in good shape?
Old Jun 7, 2009 | 08:04 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
shake the pcv valve you should hear it rattle around.
Old Jun 7, 2009 | 08:14 PM
calinotch's Avatar
calinotch
cool the valve is ok then. i guess ill just replace the screen and check on the intake in a couple months to see.
Old Jun 7, 2009 | 08:18 PM
mjr46's Avatar
mjr46
if it continues and the amount is excessive, it could be a result of excessive blowby and the result would be an overwelmed pcv system
