COOLING PROBLEM! HELP :(
Old Jun 3, 2009 | 07:40 PM
F150 StrokerCobra's Avatar
F150 StrokerCobra
Angry COOLING PROBLEM! HELP :(
the 1990 5.0 F150 and 1996 5.0 explorer side by side
i can get the explorer fanclutch type but.. i have to space it out shomehow becuase it doesnt line up with the belt drive system of the F150
i dunno what to do here:headbang:
help!
Old Jun 3, 2009 | 07:45 PM
84conversion50's Avatar
84conversion50
how much we talking for space. and are you replacing one that went out or you just cant find one to start.
Old Jun 3, 2009 | 07:50 PM
F150 StrokerCobra
the waterpump came on the reman engine i bought.. the engine is from an 1996 explorer!
and im using all of the F150 accessory brackets.. and they stick a little farther out than the explorer brackets.. so the pulley's are different.
BUT i cant use the F150pump becuase the bolt pattern on different it wont bolt on the block
note: this engine is going in a 1989 F150
Old Jun 3, 2009 | 10:45 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
can you swap on the correct timing cover??
Old Jun 3, 2009 | 11:03 PM
F150 StrokerCobra
yes but ahhh come on the engine just came out of the shop.. i dont wanna open it again to swap the cover.. hmm maybe thats the only option :S...
or to make a custom pulley spacer type but dunno
a friend has a 1990 stang and i can buy the cover from him.. those stangs use the same pump as f150's
Old Jun 4, 2009 | 06:45 AM
92tealcp's Avatar
92tealcp
Default pump
Ford changed the timing cover and water pump design I think in 1994
You will have to change the cover. If you make a spacer it will put too much side tension on the pump bearings and kill the pumps life.
Old Jun 4, 2009 | 06:57 AM
dagamore's Avatar
dagamore
might it be cheaper to put in an electric pump and just bypass that pulley? To be honest i dont know how you would run the belt with an electric pump, but it might be an option.
Old Jun 4, 2009 | 11:34 AM
F150 StrokerCobra
ok!!. i swapped the pulley from one pump to another.. so it has the same bolt pattern for the pulley and the fan clutch and now i just need to make a 1 3/4 " spacer for the pulley to line with the other belts and thats one less problem
its good to have a friend with a machine shop sometimes!
in the future ill change the timing cover.. or the belt system..
or just put an Efan on there thats better i think
Old Jun 4, 2009 | 12:06 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Have you just tried using all the front end of a mustang setup??
Old Jun 4, 2009 | 12:14 PM
F150 StrokerCobra
wont work.. its the same as an F150 setup..
