supporting mods for a blower
i currently have 30lb injectors, a adjustable fuel regulator, a anderson maf, and a 190lph fuel pump. can i support a supercharger off of these or do i need to add more? not looking to run any large size blower, maybe a s or sq trim...
edit: also will this fit with my aftermarket radiator? i know it says will only fit stock or factory replacements but so many people have these...
http://www.latemodelrestoration.com/...0%201&comp=LRS
i believe my radiator is a 2 row or 3 row
Is the motor stock? You will need an external fuel pump or redo the system front to rear to support the 30# inj. with the blower. If you don't do that you will run out of fuel under high boost/load. Stock T/B? Tell use more about what you have and want to do with the car.
How many #'s of boost do you plan on running. You will need an external pump and at least 42's to run w/o an FMU. At 14 psi, I run a pmas blow thru mass air and you'll need a tune. It ain't cheap.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
