pinging problem
Old Jun 12, 2009 | 04:44 PM
Jrichber95GTS's Avatar
Jrichber95GTS
Default pinging problem
The other day i went and got on my car pretty good and noticed it all the sudden started pinging really bad. Ive tried some octane boost thinking maybe bad gas. Then checked my timing which is only at 8* and still the car pings. Also checked my fuel pressure which is at 40# so didnt think it was that bad. I am looking for any more ideas..... Also i have a dyno tuned diablo chip so i was wondering if maybe that could be malfunctioning. I checked my timing with the bypass in and it ranged from 25* to 38* depending on the throttle. If you can give me any ideas would be greatly appriciated.
Thanks
Old Jun 12, 2009 | 08:16 PM
93_five_oh's Avatar
93_five_oh
what octane gas are you running? try premium if you don't.
did it just one day randomly start pinging? under acceleration or when?
Old Jun 12, 2009 | 09:22 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
run a koer test
Old Jun 13, 2009 | 11:13 AM
Jrichber95GTS
Always running premium will try to koer test
Thanks
Old Jun 15, 2009 | 04:20 PM
Jrichber95GTS
ok this is the first time ive ran a koer test so i think these are the correct numbers
41
21
72
136
any ideas where to go from here?
Old Jun 15, 2009 | 06:15 PM
NoGo95GT's Avatar
NoGo95GT
I am pretty sure your problem lies with those Chinese cylinder heads. JK! #41: Injectors out of balance on 5.0 SEFI; EGO sensor voltage low or EGO sensor out of range; fuel pressure out of range/#21: Cooling Temperature sensor out of specified range or ECT out of range/ #72: System power circuit fault or electrical interference or Manifold Absolute Pressure(MAP) sensor out of range/ #136: Heated exhaust gas O2 sensor fault during KOER indicated lean bank #2. Hope this helps!
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
