stumbling idle, occasional cutout
Old 06-18-2009, 10:29 PM
calgarynotch
calgarynotch's Avatar
Default stumbling idle, occasional cutout
So whenever my car warms up it seems to get a really bad idle dipping up and down with stalling. Its really bad on fuel and doesn't seem to pull very good when its warm. I've replaced: coolant temp sensor, 3g alt, starter solenoid, cleaned entire intake, reset base idle, reset tps to .96, new o2 sensors, new rad, sometimes my alternator will intermitently charge and not charge...and sometimes if I hit a big bump the car will sputter...my codes are: KOEO:85,33 KOER:93,44,33. There is a line that comes off the head that's welded shut and I have no air pump. I have no emmisions where I live...please help me out. I want to soon run this car and see its full potential. Thanks
calgarynotch is offline
Old 06-19-2009, 03:06 PM
calgarynotch
Anyone got any solutions?
Old 06-19-2009, 09:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
perform the ford wiggle test = with car running go around and lightly tug and or wigglr wire harness and all connectors and see if you notice a difference it the way it runs when the prob area is wiggled
mjr46 is offline
Old 06-19-2009, 09:25 PM
zebo87
zebo87's Avatar
with what you are saying about the alternator the wiggle test is a must. also make sure the connections to the alternator and battery arent corroded. you could have a ground or short also.
zebo87 is offline
Old 06-20-2009, 03:47 PM
calgarynotch
Yeah all the charging system is new. I notice SOMETIMES the alt won't charge then I can smack the dash and it it will dip back up and then it will start to do its stupid wonky idle again. Its so tempermental on how it runs. It has some Heat soak power fade I noticed as well. Ill try the wiggle test. Any more suggestions would really help me. Gas is over 1.00 a litre again
ak98
02-18-2023 08:36 AM
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: stumbling idle, occasional cutout
