electronics problem?
Old Jun 30, 2009 | 11:27 AM
Arostang's Avatar
Arostang
Default electronics problem?
ok so my radio only has barely any sound coming out of one speaker and my odocluster is messed up all the readings are wrong what would you do?
Old Jun 30, 2009 | 02:24 PM
kilby94's Avatar
kilby94
That is the most vague question i've heard in a while..
Old Jun 30, 2009 | 02:28 PM
kilby94's Avatar
kilby94
Is your battery at full charge? Is the charging system working like it should? Was your radio working before, and then started messing up? Did you cluster just start messing up? How do you know the cluster is not working? Have you changed anything electrical out recently?
See where i'm going with this? Give a little more info....
Old Jun 30, 2009 | 07:02 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
replace the speaker or use a know good one to test with...duhhhhhhh...............and elaborate what odometer all messed up means??????
Old Jul 1, 2009 | 11:19 AM
Arostang's Avatar
Arostang
sorry sorry, i got the car like this, the odometer was replaced with a electronic one and the speedometer just reads 8.8.8 the oil pressure is measured in precentage and it constantly drops to 0 from 99 and the rpm&gas gauge arent very accurate
Old Jul 1, 2009 | 01:31 PM
kilby94's Avatar
kilby94
In that case i would get new gauges.. When it comes to oil pressure IMO i want to know exactly what PSI i'm at, instead of a percentage.. I would put a factory cluster back in it, and get good aftermarket temp, oil pressure, and fuel pressure gauges.. But thats just my opinion..
Richard
Old Jul 1, 2009 | 02:46 PM
Arostang's Avatar
Arostang
thats what i was thinkin but how simple is it to get a new odo cluster and recalibrate all of it?
Old Jul 1, 2009 | 08:21 PM
mjr46's Avatar
mjr46
you don't have factory gauges therefore we can't help you, what you need to do is find a owners manual by going to the site and or manufactorer of the cluster
Old Jul 4, 2009 | 12:30 PM
Arostang's Avatar
Arostang
ah ha thank you
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
yourmom6990
Sep 14, 2015 10:52 PM
zanemoseley
Sep 6, 2015 12:58 PM
