fuel/ecc problem
i was driving down the road when my car bucked and stalled i check my fuel press guage no pressure after hours on hte side of the road with a test light i tried and tried but couldn't figure it out, when i jump the pump relay under the seat i get pressure so i believe my problem is my ecc relay but i cannot find it, i found the relay under the maf on the inside 1/4 panel is that it? the colors of hte wires dont seem to line up with that relay and my diagram
im frustrated and confused please help
the ecm controls the ground for the fp relay under the seat as long as ecm sees PIP sent to ecm by tfi then it grounds the relay windings, you may have a bad fp relay as long as you have the proper inputs to relay you can test it with leads and a dvom
my fav game too! i have to find a short for my radio/fuel door/courtesy lights fuse... fun fun
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
