climate control problems
Old Jul 25, 2009 | 05:04 PM
gregamuffin's Avatar
gregamuffin
Default climate control problems
my problem is that at first it only worked on defrost. no matter what setting i selected only defrost worked. after some research on here i found that i needed to look for a vacuum hose leak or disconnected. after searching i found it and was really excited! but then after messing with a few other things like getting my radio to fit flush and removing the airbag module behind the controls (which eliminated that awful beeping) i went to try my vents and stuff and it wouldnt turn on at all. i know all the connections are good as they worked yesterday and i checked twice that i reconnected everything i undid behind the dash so what things should i check? it wont blow at all but i doubt my blower motor went it seems like i knocked something loose
Old Jul 25, 2009 | 05:07 PM
mustangsneverdie's Avatar
mustangsneverdie
check fuses
Old Jul 25, 2009 | 05:12 PM
gregamuffin
will do...any other suggestions?
Old Jul 25, 2009 | 06:13 PM
gregamuffin
good call, checked the fuses one wasnt in all the way vents and other settings working fine thanks for the help
Old Jul 25, 2009 | 10:39 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
good deal
Old Jul 26, 2009 | 03:23 AM
mustangsneverdie
no problem
Art161
Sep 9, 2015 10:33 AM
Sep 8, 2015 11:50 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
M3hunter
Sep 5, 2015 03:42 PM
