88 speed density with crane ca
Old Nov 16, 2003 | 12:44 AM
teresa500's Avatar
teresa500
Default 88 speed density with crane ca
i've heard i need mass air to fix idle problems,what should i do next for more power?it's an auto.do hypertech modules work?any help would be a bonus guys!
Old Nov 16, 2003 | 12:54 AM
jhogan2424's Avatar
jhogan2424
yeah, i've been told that the speed density cars don't react well to cam swaps. You shoud do a mas air conversion. It should smooth things out.
Old Nov 16, 2003 | 01:05 AM
teresa500's Avatar
teresa500
thanks,any info on the other?</P>
</P>
Old Nov 17, 2003 | 04:20 PM
Quik's Avatar
Quik
any mods you do to a speed density car is not the forgiving. you can either do a conversion or keep the speed density and get it tuned but this cost some serious cash. most cars running the speed density do run fast but were talking about straight out race rides.
Old Nov 17, 2003 | 10:23 PM
jhogan2424's Avatar
jhogan2424
#1 Mass air conversion with73mmmass air meter</P>
#2 3.55 Gears</P>
#3 Shorty headers and an offroad h-pipe with flows</P>
#4 Transgo Shift kit</P>
#5 Edelbrock Performer Intakeand 65mm BBK throttlebody</P>
#6 MSD ignition, coil, and some good wires</P>
These mods should get you where you want to be. If you want to be faster than this you're gonna have to tear into the guts of you motor. You can always add nitrous for a cheap kick in the pants but you HAVE to know the limits of your car or you WILL wish you had never laid eyes on that little blue bottle of juice. Trust me, I learned the hard way. </P>
</P><edited><editID>jhogan2424</editID><editDate>37942.8521990741</editDate></edited>
Old Nov 18, 2003 | 03:02 AM
Quik's Avatar
Quik
you can build a twin turbo set up for around 1500, bolt it up to a stock stang and run in the high 11s
Old Nov 18, 2003 | 12:36 PM
jhogan2424's Avatar
jhogan2424
Don't believe that BS about the twin turbos. You can NOT build a setup for around 1500. And in my opinion, turbos are on the bottom end of the power-adder totum pole. Just keep it kinda simple with the add-ons I listed above and you will be happy.
Old Nov 18, 2003 | 12:39 PM
vfast's Avatar
vfast
I ♥ Acer
ohs...........ok build me one for 1500.00 no **** and I'll buy it if it runs
i'd go with a 76mm mass air.. or you can go carbed for about the same$$$$$$ which is easily tuned
Old Nov 18, 2003 | 02:34 PM
Quik's Avatar
Quik
since you dont believe me her is his site. the kid ran 18psi thru a stock 5.0
www.turbomustangs.com/robd<edited><editID>ohsoquik02</editID><editDate>37943.5251041667</editDate></edited>
Old Nov 18, 2003 | 02:38 PM
Quik's Avatar
Quik
he used two svo turbos.two supercoupes intercoolers, tubing is hoses, ran 30lb injectors, 255 fuel pump, had 373 gears, 4speed toploader. sfmu. you to take in the cost that the parts were USED! main key.
