is this overheating? 233 before t-stat & 240 after T-stat
Old Aug 28, 2009 | 09:52 PM
kennebellgt's Avatar
kennebellgt
Default is this overheating? 233 before t-stat & 240 after T-stat
is this overheating? 233 before t-stat & 240 after T-stat?
Thanks Guy's.
Edit: This is 2-4 minutes after shutting the car off, I used a Non-Contact thermometer.
Old Aug 29, 2009 | 01:44 AM
luckythirteen13's Avatar
luckythirteen13
where are you getting these numbers from? what t-stat do you have? idealy you want to be in the 180-200* range.
Old Aug 29, 2009 | 04:41 AM
kennebellgt
I have a stock temp. t stat, and i put the thermometer on the t stat housing than after the t stat housing and thats how i came up with those numbers
Old Aug 29, 2009 | 10:39 AM
hillbilly pony's Avatar
hillbilly pony
weird...did you put the thermostat in backwards...did you have problems before you swapped.
Old Aug 29, 2009 | 10:43 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
So this is after the car is shut off and just sitting? If so, of course it is going to read really hot, there is no coolant circulating in the engine and no fan to cool off the radiator.
Old Aug 29, 2009 | 07:49 PM
kennebellgt
Angry
Okay, I pulled off my radiator cap today and i got a strong smell of gas in the radiator and the same gas smell in the reservoir tank, and inside the res. tank it bulbbles alot, and with the radiator cap off, it starts to bubble and shoot water out it only does this when it starts to overheat. I dont understand i just put these heads on, how could the headgasket go bad that fast, and i get no smoke at all of any kind out of my ehxaust and no smell either, but i havent been running coolant, because ive been flushing and refilling constantly. I am thinking either a headgasket or what else could it be, how could it not be smoking out of my exhaust GRR
Old Aug 29, 2009 | 07:54 PM
86 5.0L's Avatar
86 5.0L
im going to go ahead and call this a case of heatsoak, what does you temp gauge read?
Old Aug 29, 2009 | 09:26 PM
kennebellgt
heat soak? and it was getting up to 225
Old Aug 29, 2009 | 09:43 PM
Tony71502's Avatar
Tony71502
You took the rad cap off when it's hot? No wonder it shot **** at you. If the temperature is above the boiling temp at your elevation/atmospheric pressure.... of course it's going to boil and spray at you. The point of a pressurized coolant system is to keep the coolant in liquid form above its boiling point.
Old Aug 30, 2009 | 08:02 PM
kennebellgt
LOL i know not to do that im talking about leaving the cap off until it warms up then it started boiling over
