check engine light question
Old Sep 23, 2009 | 07:50 PM
huntersn9525's Avatar
huntersn9525
Default check engine light question
My check enginge light comes on for a few seconds then goes off. It does this under any driving conditions and seems very inconsistant as to how long it stays on and when it comes on. Do I need a special computer to pull the codes or can it be done with a Volt Meter andhow do I do that? Anyone got any suggestions I would like to hear them.
Old Sep 23, 2009 | 08:21 PM
KingCobra50's Avatar
KingCobra50
The codes can be pulled without a scanner. You actually don't even need a volt meter you can do it through the check engine light. All you will need is a small piece of wire and a pen and pad to write down the codes.
Heres a link with a pretty good step by step guide for running the KOEO, KOER, and Cylindar Balance tests:
http://sbftech.com/index.php/topic,2471.0.html
This is a link to a list of code descriptions:
http://sbftech.com/index.php/topic,849.0.html
Good Luck!
Old Sep 23, 2009 | 08:46 PM
huntersn9525
man thanks alot that will really help!!! I am new here and everyone seems very helpful
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
