no spacer
Old Sep 28, 2009 | 10:39 PM
94mustang94's Avatar
94mustang94
Default no spacer
What are some downfalls of not running a spacer of my driveshaft of my 94 gt with a tremec 3550?
Old Sep 28, 2009 | 10:57 PM
Liquid_02's Avatar
Liquid_02
What do you mean by spacer? As driveshafts don't have spacers so you got me goin here... aha
Old Sep 28, 2009 | 11:09 PM
94mustang94
the 5/8 spacer you run on the rear of the driveshaft to make up the difference in lengths of trannys
Old Sep 28, 2009 | 11:15 PM
Liquid_02's Avatar
Liquid_02
I have never ever seen a band-aid like that before.... Though if your shaft is indeed that 5/8" short you will need it or you're going to lost 5/8" of spline in your trans to transfer the power. I would personally just get the shaft lengthened for the 100 bucks that would cost though... I wouldn't want a spacer on one of the more fragile parts of the driveline
Old Sep 28, 2009 | 11:17 PM
mattdel's Avatar
mattdel
hmm... i'm trying to imagine how a spacer would work at the rear of the driveshaft?
i think someone is blowing smoke up your *** here. probably need a longer slip yoke, not a spacer.
Old Sep 28, 2009 | 11:21 PM
94mustang94
http://www.latemodelrestoration.com/item/ST-5557705
thats the spacer. no smoke here
Old Sep 28, 2009 | 11:22 PM
AdderMk2's Avatar
AdderMk2
Banned
no smoke... I have said spacer, it eliminated my driveline vibration.
Old Sep 28, 2009 | 11:32 PM
94mustang94
adder what kind of vibrations did you have i seem to have one at higher speed its like and intermittent vibration. and them sometimes at high rpms i have shifter shake. but the vibration is wierd because it vibrates stops vibrates stops vibrates stops and im going down the interstate at like 70
Old Sep 29, 2009 | 12:21 AM
AdderMk2's Avatar
AdderMk2
Banned
yea, it was around 70-80mph and would shake the whole car, 'cept the steering wheel.
put the spacer in and almost all of it went away. The rest went away when I set my driveline angle back to stock. Now i need to set pinion angle, and ill be done
Old Sep 29, 2009 | 11:07 AM
Jfsram's Avatar
Jfsram
It will set the splined yoke deeper into the transmission. Having it stick out too far will cause a wobble. I failed to correct this on a 383 Dodge Dart and broke the tailshaft of the transmssion at 120mph.
Since then I always run the yoke as close to the transmission as possible. 1/2 to 3/4" depending on the rear suspension design.
The ultimate would be a proper length driveshaft but it's $50 vs north of $200.
